hi
im new to meshmixer and i made this articulator
so far works pretty good the problem is that when i move the top part with the piviot the rotation circle wont stop at the 90* angle. and thats what i need it to do.
is there any function that can give the pivot rotation a desirable stop?
thnks
@Anonymous You posted in the Inventor forum.. I have asked the forum moderators to move your post to the Mesh Mixer forum where someone should be able to assist you..
And here we are:
If you drag a rotation-arc in Transform there's a circle of snapping increments. If you move the mouse over this circle (still keeping LMB pressed) the rotation snaps to those increments. You can increase/decrease these increments (while they are visible) via the up/down buttons on your keyboard.
Another way to get precise rotation is to set the rotation in the tool's flout by numerical input directly (RotateX, RotateY, RotateZ).
Gunter Weber
Triangle Artisan
