Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
meshmixer tools not working, red lines
3 REPLIES 3
1375 Views, 3 Replies
Why do I keep getting these red lines and meshmixer tools don't work (ie. extrude, smooth boundary, and several other tools)
3 REPLIES 3
MagWeb
Red lines in MM highlight non manifold issues (more than two faces share the same edge or a "spinning off" face is connected to a closed surface by a vertex). Such issues make most tools fail...
Did you get this result using MM tools before (if yes what was your workflow?) or did you import from another application?
Gunter Weber
Triangle Artisan
in reply to: MagWeb
I imported an STL file from blue sky bio
MagWeb
Can you post the file here (or load it to some file sharing service and send me the download link via PM).
I'll look into it.
Gunter Weber
Triangle Artisan
