Announcements
Help Designing using current 3d scans
paulHNAV3
paulHNAV3
Is there someone out there that can give me some pointers on how to design quicker for a particular design I am doing? I am willing to do a screen share.
Accepted solutions (3)
MagWeb
Yes, I'm here.
Gunter Weber
Triangle Artisan
paulHNAV3
here is my current work flow can you help be get faster and more well defined?
https://autode.sk/341GvwP
MagWeb
You might try a workflow based on PlaneCut to get a straight bracket:
It might be necessary to do  Remesh or Reduce before.
  • Smooth the nose holes boundaries using the SCULPT>Smooth brush
  • SELECT>Modify/SelectAll (Ctrl+A) and run Edit/Offset at a negative value to get the thickness of the sides of the nose:
  • Select the transition region at the nose holes and run Deform/Smooth:
  • Use EDIT/PlaneCut set at NoFill to cut the upper edge of the horizontal bracket bar:
  • Run EDIT/CreatePivot at FromLastTool PlacementMode to save the cut's position to a pivot
  • Again run EDIT/PlaneCut with NoFill to cut the vertical outer edges of the bracket:
  • Again run CreatePivot at FromLastTool to save that cutting plane's orientation to a pivot
  • Once again run EDIT/PlaneCut. Click on the upper pivot to make the cut snap to this orientation. Move the plane with snapping enabled to get a parallel cut. This time set PlaneCut to CutType= SliceGroups:
  • Do the another cut of groups using the other pivot:
  • Select all groups you do not need for the bracket by double click and hit X to discard these surface regions:
  • SELECT the two face groups inside the nose holes and crop them to the needed length using SELECT/Edit/Plancut (this restricts the cut to selected areas only)
  • Now SelectAll (Ctrl+A (Cmd+A on Mac)) and run SELECT/Edit/Offset to give the bracket the needed thickness (this time a positive value)
  • Now you might run Deform/Smooth:
  • Done:
Gunter Weber
Triangle Artisan
paulHNAV3
Thank you MagWeb this has helped a ton! last question is how do I measure the length of just the Hook? (see attached picture) for example if I need the part that wraps around the nostril and goes in the nose to be 10mm how do I define that measurement?
MagWeb
Before doing the cut on the interior surfaces (9th image above) use EDIT/Align to move the piece to the ground plane:
(You might use EDIT/Transform to move/rotate it so the base grid intersects the object where you want the measurement's start plane)
Now select the interior groups as in image 9(above) and do SELECT/Edit/PlaneCut.
Make sure that snapping is on (the small S circle needs to be green - if not: Click it) , also the A circle (absolute coordinates) and the W circle (World frame).
Now dragging an arrow you'll see snapping increments. If needed, refine the increments using the up/down arrows on your keyboard.
Gunter Weber
Triangle Artisan
paulHNAV3
Thank you very much for your help! this works wonderfully
