Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Meshmixer not offering "sequence" options (STL Binary Sequence ... , etc)
1 REPLY 1
autocadFH8KR
441 Views, 1 Reply
In Meshmixer 3.5.474 I have done:
> Import STL
> Select an area
> Create Facegroup
> Generate Complex
> Split Complex
Now I want to export the two resultant objects, which will require STL Binary Sequence, One file per Region ... but that option does not appear in the menu (as seen in the screencast)
https://autode.sk/33qcLc5
Of course, when I choose the available STL option, I get a warning that the object is a complex, and the result may not be valid.  Sure enough, the result is not openable by any app I've tried.
How do I make the necessary STL Binary Sequence ... option appear on the Export format options?  Or what do I need to do differently?
1 REPLY 1
MagWeb
in reply to: autocadFH8KR
You need to export the something(complex) object  (NOT the split parts) to get the sequence options in the export's format dropdown.
Gunter Weber
Triangle Artisan
