Updated my MacBook Pro to Catalina. Opened Meshmixer first time since updating to the new OS. Now when opening Meshmixer, get this error (screenshot). App then opens, but crashes when trying to upload stl. Any help greatly appreciated.
Did you check the libraries folder and its subfolders if the OS update kept the contents?
In Documents/meshmixer/libraries there should be 4 directories:
If there's no content in these directories I would try to do a fresh installation of Meshmixer.
If there's content: Check if Catalina protects the documents folder in some way. You might try this:
Gunter Weber
Triangle Artisan
Thanks for your help and reply.
Turns out all it was is somehow I disabled Meshmixer's access to the Documents folder and it resulted in this error.
Thanks again.
