Setting and tracking landmarks
mdhan82
mdhan82
Meshmixer question:
Is it possible to set certain landmarks on an object and track the coordinates of each landmark as the original object is transformed?
For example, if I have a cube and set each of the 8 corners as a landmark, can I get the coordinates of these landmarks after I translate and rotate the cube?
Any help would be greatly appreciated, thank you!
You can use Pivots.
For the cube example:
Run EDIT/CreatePivots. Set its PlacementMode to SnapToVertex (any other placement mode should work too) PLUS enable LinkToTarget. Double click the 8 corners to drop pivots there.
Now do your transformations.
To get the pivots' positions after the transformation click on a pivot (> should be orange now) and run EDIT/Transform.
Enable EnableSnapping and AbsoluteCoords/Sizes. Now the values at TranslateX, TranslateY, TranslateZ show its absolute coordinates.
Sorry, forgot: You need to set Transform to CoordinateSpace = WorldFrame as well of course.
mdhan82
Yes! Thank you so much. It worked beautifully.
