I love the UV Distorsion view in the UV Editor, but alas I don't want it to show in the 3D Viewport simultaneously. Therefore I need to constantly switch between normal checkers and distorsion in the UV Editor, when I want to assess things in the 3D Viewport.
Can I set it up so I have normal checkers in viewport and distorsion in UV Editor?
Solved by hamsterHamster. Go to Solution.
Apply Unfold, which will distort/average UV's based on their 3D relative distances.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the ACCEPT SOLUTION button, so others might find it much more easily.
I'm not sure I follow what you mean. I'm trying to have:
- UV-checkers in my 3D viewport, and
- UV-distorsion in my UV-editor.
Want to mix those display modes in different views.
Ok, got it now.
As much as I've tried, no, impossible, at least I couldn't figure out how. However, you can decrease the Distortion amount to 0.5 and get equal mix of checker and distort. UvEd > uvDistortion [options]> Alpha: 0.5
,,,_°(O__O)°_,,,
