Unable to disable UV shell in viewport
Hello, I was trying to use UV editor in MAYA 2020, but the window is not showing when clicked. Instead, my mesh is shown with UV shell colours in the viewport.
I can only find the UV editor window that when use "UV editing workspace",  is there a way to open it in the Classic view or disable the UV shell to show in my viewport? Thanks a lot!!
hamsterHamster
In M2019 colors go away as soon as I close uvEditor.
Besides, if you still need the uvEd to be kept open, you can switch to wirefame shading:
(hotkey 4 within the uvEd)
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
Hi I tried, but the UV editor window is not coming out when I click on it. I can't find it so can't close it...
hamsterHamster
It possibly is somewhere off-screen, especially when minimized - happens all the time with my monitors |-- arrangement.
Try minimizing Maya, then restore. Also the Display>Workspaces>.. has a list of presets.. in my case it was Maya Classic, which restored the uvEd.
,,,_°(O__O)°_,,,
Oh it works! Thank you
