Hello, so I'm relatively new to Maya, but during the last few weeks when I've been using it, Arnold renderer was working fine. Now when I try to open options for render current frame, batch render, or render sequence, I get an error like this:
// Warning: file: C:/Program Files/Autodesk/Maya2020/scripts/others/renderOptions.mel line 19: Renderer "arnold" does not provide render options.
Any ideas?
Solved by mspeer. Go to Solution.
Hi!
There are no such options for Arnold, simply don't try to open the options window.
If you want to change any Arnold settings, then please open the Render Settings window instead.
Thank you! I thought that meant just the name of the save and not the actual location. It makes sense now.
Cheers,
Theo
