Texture File not rendering in Arnold
Hello, I am fairly new to Maya and I am trying to make a simple wooden chair. I am using the Arnold render, I downloaded a wood texture from the internet and I put it on the chair but every time I render the image the texture isn't showing up. Please helpI am using an ai standard surfaceI am using an ai standard surface
parabhdeep
As I can see the shader is not assigned to the whole chair mesh,try it and check the texture path also.
I tried putting the texture on the entire chair and I still get the same result, no texture is on the chair when I render in Arnold.
mspeer
Hi!
Please upload a scene-file + the texture.
Here is the entire folder with everything.
mspeer
Hi!
In Render Settings -> Arnold Renderer ->
Diagnostics -> Feature Overrides -> Ignore Textures ("disable")
