Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
SOFTWARE RENDER FAILS WITH ANY CAMERA ATTACHED TO A MOTION PATH
2 REPLIES 2
garrettmin
352 Views, 2 Replies
Procedure:
  1. Attach a Renderable Camera to a Motion Path (Nurbs Circle) & Software Render
    1. Tested Fail:
      1. Intermitently Fails Software render in batch:
        1. Any New Camera, aim, aim / up
        2. With Camera under a transform node which is then attached to a nurbs circle & attached to a motion path.  Tested different camera & motion path transform node hierarchies all same result, failing software render.
    2. Tested Success:
      1. Deleting Camera from Motion Path
        1. Removal of camera from Group Node containing motion path constraint
      2. Allows the software render to continue without fail the entire sequence.
2 REPLIES 2
garrettmin
in reply to: garrettmin
Solving by way of "Hiding & Deleting failed nodes"
Through a process of trial & error, hiding & deleting nodes in the hypergraph reveals what geometry is faulty.
Maybe this will eventually render
garrettmin
The problem was:
Failed Geometry in Node Hierarchy.
Debug Node Hierarchy & rebuild geometry.
