smooth wireframe rendering without subdivid
ZEICHEN.TRICK
Message 1 of 18
ZEICHEN.TRICK
Hey folks,
im tryin to render out the smooth wireframe of a screw-model like this
screenshot
but maya render it out with subdiv like this
how can i fix this....
best Rick
Replies (17)
Message 2 of 18
J450NP13
So you want a vector rendering?
Message 3 of 18
ZEICHEN.TRICK
i dont know,
i want to render out the wireframe in mental ray like the smooth wireframe preview in the viewport.
and when i do that maya add subdivision to the wireframe...
Message 4 of 18
J450NP13
Try a vector render.  I am not sure if 2016 has that option...it is still in 2015 I am pretty sure...I don't have it in front of me.
Message 5 of 18
ZEICHEN.TRICK
i try it and its the same problem the vector render also render out the low quality display wireframe and not the smooth mesh preview
Message 6 of 18
J450NP13
I don't know...it seems as though 2016 has jacked a bunch of things up.
Message 7 of 18
ZEICHEN.TRICK
im working with maya 2015 and yes youre right
the only way i could find was to do it with the maya vector render after checking some youtube videos
Message 8 of 18
J450NP13
Did you have to set a setting in render options in the render settings?
Message 9 of 18
ZEICHEN.TRICK
what kind of setting you think about
Message 10 of 18
ZEICHEN.TRICK
this is the vector render result
its actual that what i want but i dont believe its not possible im mental ray as wellfrontview2_wireframe.jpg
Message 11 of 18
J450NP13
Rgr that....I couldn't use mental ray either.  But there is no reason to use mental ray...it is just vector lines.
I thought there was a setting in the render options you have to enable to get it to work....I may be wrong.
Message 12 of 18
ZEICHEN.TRICK
yes its just vector lines but i can render the wireframe with the material in MR and now have to composite it in photoshop but its no problem
thanx for your advice
Message 13 of 18
ZEICHEN.TRICK
the way it works with the vector render is
  • select and set the edges at the low poly state of your model (Create/Sets/Quick select sets)
  • after that select your model and convert smooth mesh preview to polygons (Modify/Convert/smooth mesh preview to polygons)
  • than you have to soften all edges (Normals/soften edges)
  • now you select your model and turn in the EDGE mode and go to quick select set (Edit/Quick select sets) and choose your set from the first step. Only the edges of the low poly state should be selected now
  • the selected edges from your set have to turn in to hard edges (Normals/Harden Edge)
  • open render settings choose maya vector render
  • turn of fill object in the fill options settings
  • in the Edge Options settings next the fill options are all the relevant setting which effect the look of your wireframe
  • make your settings and render
now you have a render of the smooth mesh preview wireframe that appears in your viewport after pushing 3 on your keyboard
Message 14 of 18
ZEICHEN.TRICK
Message 15 of 18
J450NP13
Rick did you try it with MR with all edges set to hard?  Set to face?
Message 16 of 18
ZEICHEN.TRICK
no but i will try it
...what is the effect of set to face?
Message 17 of 18
J450NP13
I think it is the same as setting all the edges to hard...but it may be to the face and not the edge.  If that makes sense.
Message 18 of 18
ZEICHEN.TRICK
I break up testing around to make it working with MR
because afterwards has the vector render some benefits
already its always a benefit if you can change the look of parts from your animation separate...
so i can change the color of the wireframe and add some gradient...
