ShaderFX render targets (using custom camera)
Message 1 of 1
I have been working on a a tool that allows you to build heightmaps/textures through using render targets.
The idea behind it is to use a topdown camera to capture the depth and color buffer and feed it to a shader (tessellated shader) that does the compositing of those render targets.
I have managed to make it work in Unreal Engine and in Houdini through a different method.
Houdini engine prototype:
The downside of this method is that Houdini needs to output geometry back to Maya every time you do a change.
It tends to get slow if the output geometry has a high polygon count.
Unreal Engine shader method :
The method I would like to get working in Maya. Uses a camera which renders to texture the Depth and color buffers and feeds them back to a tessellation shader.
The final output is saved to disk.
Now I'm trying to redo this method in Maya through ShaderFX and I happen to stumble on a blog post on Shaderfx's website which shows how to make use of render target in Maya :
http://www.shaderfx.com/2014/11/setting-up-render-target-can-be-tricky.html#comment-form
 I have been trying to figure out if it is possible to use a different camera (other than the perspective camera)to capture the depth and color buffer in ShaderFX without much success.
The idea is to simply tell the shader to use a custom camera and render to texture what it sees in real time.
I would really appreciate If anyone can share an idea or a direction on how to accomplish this.
Amir
Replies (0)
