ramp shader problem
ramp shader problem
begerdesign
ramp shader problem
begerdesign
I have a probably simple problem. If I create a smooth circular ramp, it does not appear homogeneous, but has an annular line (see image with arrows). This also happens when I use an image with a ramp as texture file. How can I avoid this?
Tom
mspeer
Hi!
Sorry, the only thing i can see here are compression artifacts from the JPEG format.
Please search for "color banding" which might be your problem.
begerdesign
Indeed the artifact came from compression and the lines/steps i saw were because of a wrong setting in color management for my display.
