Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Pink material in Render Arnold???
6 REPLIES 6
21952 Views, 6 Replies
I have a problem while Rendering, that is some parts of the render are displayed in a pink material??
Does this have a solution?? How I get rid of this??
6 REPLIES 6
Zeriel00
I haven't used Arnold, but you could try deleting your Material and adding a new one, it seems like those faces have no material on them. Are they facing the right direction?
Stephen.Blair
Magenta (pink) means a missing shader. Check the Arnold log. And remember that if you use the Arnold Render View, then by default we show the log for the last progressive step only.
// Stephen Blair
// Arnold Renderer Support
in reply to: Stephen.Blair
Thank you for all!! It really helped soo much!!
Hope to count on you if i get some trouble.
I have the same problem and no solution despite my research and tries ...
Could you explain more in details the process ?
Thank you very much !
Stephen.Blair
Hi
What shaders are you using?
Check the Arnold log for warnings and errors about unknown or unrecognized nodes.
https://support.solidangle.com/display/AFMUG/Diagnostics
// Stephen Blair
I have the similar problem and no solution, the difference is the problem appeared when I used  batch render.
Most of them are correct, but there are a few frames where an object appears pink at random.
