I have a problem while Rendering, that is some parts of the render are displayed in a pink material??
Does this have a solution?? How I get rid of this??
Solved by Stephen.Blair. Go to Solution.
I haven't used Arnold, but you could try deleting your Material and adding a new one, it seems like those faces have no material on them. Are they facing the right direction?
Magenta (pink) means a missing shader. Check the Arnold log. And remember that if you use the Arnold Render View, then by default we show the log for the last progressive step only.
Thank you for all!! It really helped soo much!!
Hope to count on you if i get some trouble.
I have the same problem and no solution despite my research and tries ...
Could you explain more in details the process ?
Thank you very much !
Hi
What shaders are you using?
Check the Arnold log for warnings and errors about unknown or unrecognized nodes.
https://support.solidangle.com/display/AFMUG/Diagnostics
I have the similar problem and no solution, the difference is the problem appeared when I used batch render.
Most of them are correct, but there are a few frames where an object appears pink at random.
