Perspective distortion in render
Message 1 of 28
Hi!
Why do my renders differentiate so much from viewport view? It is driving me crazy. I have a low poly model of game weapon and in viewport looks nice , but when i render it it looks wider and shorter. I changed focal length , angle of view in my camera. Nothing worked. Any help would be much appriciated.
Replies (27)
Message 2 of 28
Another image
 White one is rendered, gray one is in  viewport .Both models are 1:1 scale.
Message 3 of 28
damaggio
Are you rendering from the same camera....what renderer are u using?
Message 4 of 28
Thank you for the reply.
Yes, I am rendering from same camera. I am using mental ray. I also tried maya software and v-ray. Same result. Here are my render settings. I tried changing device aspect ratio to 1.5 and it helped a little bit with length of the gun, but it distorted its width. Changing angle of view and focal length in the camera attributes didn't help either.
Message 5 of 28
damaggio
No you are not, render settings say perspective cam but you have another Camera1.
Message 6 of 28
damaggio
change render settings to renderable camera1
Message 7 of 28
I have. For some reason there no difference from perspective . I renamed the prefs folder to prefsOLD. That should load default settings. No matter what i pick under renderable camera(persp, front, back) render uses camera1. This is strange.  I uploaded scene so you can take closer look if you like. It is only a concept so far. But I need good render for paintover.
Message 8 of 28
damaggio
Let me take a look in a few hours . I'm in the middle of some render tests...its good that you got some new prefs, that should help us find the issue.
Later.
Message 9 of 28
damaggio
looks like you are using Vray...are you using a vray camera?
Message 10 of 28
pshwayka
Just jumping in here for a second. I think the "Renderable Camera" setting is only honored during a batch render. If you click on Panels->Perspective, you can pick the camera that you are looking through, and that will also be the camera used when you render the current frame.
Message 11 of 28
Thank you. No I am using regular maya cameras.
Message 12 of 28
damaggio
I just did a render, is totally off, is not rendering camear1, only the perspective camera...something is wrong maybe with camera 1...try deleting and creating a new camera.
Message 13 of 28
Interesting. Thx for the info. I didn't know that only works in batch renderer. I usualy use panels->perspective->camera1, so I don't change renderable camera setting too often.
Message 14 of 28
pshwayka
That's really strange...camera1 worked fine when I tried it.
Message 15 of 28
Created a new camera, same result. Is something wrong with my maya install?
Message 16 of 28
damaggio
Thanks Pshwayka but is not rendering camera 1 at all...I created a new camera and now it renders.
Message 17 of 28
damaggio
Are you on Mac...maya latest SP?....im on PC
Message 18 of 28
Does it renders correctly? I created 3 new cameras . Always same distortion. Am i being too demanding? Is it normal for that kind distortion to happen. I have been using maya for a year now and I don't think I had problem like this before. I am using Win 8.1 64bit and maya 2015 latest SP6.
Message 19 of 28
damaggio
All cameras are rendering now using the Render view>and choose a camera...seems to be accurate but I'll need to compare very closely, maybe in photoshop... I rotate the gun so the ends are touching the frame edge and looks accurate.
Message 20 of 28
Did a quick render. It is really noticeable when viewed from top. It is like resolution gate is not displaying correctly.
