Orthogonal render different from the camera view
Hello Everybody,
i would like an help to set a camera in Orthographic Mode and to understand how it works beetween v-ray and the Orthographic view of maya camera.
I need to take a render of a building to start a videomapping project. I realised that there is a problem between what i see in the scene (camera) and the final render.
IMAGES:
https://ibb.co/kNfdqa
https://ibb.co/csdniv
Basically in the scene i have:
1. Asset
2. Camera with ImagePlane (In the image plane blocked to the camera i have the contour image that i need to fit in the same size with the asset)
Camera settings:
Orthographic View (enabled)
v-ray physical camera enabled
Camera Settings Type Orthogonal
why is it rendering like this? What i made wrong?
Thank you so much!
Appears to be a bug which continues through 2018
cjwidd
Is this a confirmed  bug, for example has a bug report been submitted and the issue has been resolved in a subsequent version or service pack?
This is an unusual bug, given that it is such a simple behavior, i.e. viewport matching, scaling, etc.
