Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Normal map and roughness still look bad on model despite the map is set to raw, seam patches visible, odd emeril grind angle that differs between UVs
7 REPLIES 7
Message 1 of 8
FluffyRaven
311 Views, 7 Replies
Tags (2)
Labels (2)
7 REPLIES 7
Message 2 of 8
Where does the normalmap come from?
How does the geo look like?
https://linktr.ee/cg_oglu
Message 3 of 8
Normal map comes from substance, baked high poly sculpted mesh onto low poly mesh
98danielrico_0-1692602619119.png98danielrico_1-1692602878125.png98danielrico_2-1692602912483.png
it looks fine on iray.
Message 4 of 8
Is it possible that the normal on the mesh are locked?
have you exported the textures with the Arnold preset for openGl?
Message 5 of 8
No, mesh normals aren't locked, and i started with DirectX. That's how SubstancePainter is preset to.
Message 6 of 8
Change it to openGl and use the Arnold preset.
Message 7 of 8
Did it, nothing has changed.
Message 8 of 8
Be sure to check Alpha is Luminance for both maps.
Technology Administrators
