- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi I was rendering some hair through Xgen and Arnold and everything was working fine until I think it was after I resized the plane that the roots were attached to, which seemed to have caused this error:
// Error: XGen: Clumping guide ID larger than number in xuv file (pPlane2): 172(guide ID) 0(xuv file size) [PH_Head_Hair,PH_Mid_Hairs_002,Clumping2]
I searched online for a solution, but the only solution Autodesk describe for this problem is to regenerate the clumping data. So I deleted the modifiers and created them again but the problem still persists and it seems that the problem has also spread to my descriptions of hair as the error claims that other descriptions now have the same problem and so none of the clumping works now. Can someone please specify what it means by regenerating the clump data if I am not doing so correctly? Also what else can I try?
Thank you,
Peter
