Maya Render View Slow Compared to Arnold Render View
a.szertaridisz
a.szertaridisz
I have a question regarding rendering a sequence with Maya.
When I render a still in Arnold renderer, it takes about ~30 minutes to render, which is fine.
But then I launch a Render Sequence in Render View with the exact same settings (starting on the same exact frame) and my render time expands to 2 hours per frame.
Is this supposed to be normal? Can I adjust something in Render View, to get it to render the sequence faster?
Any help would be greatly appreciated
Alexisz
Replies (9)
Christoph_Schaedl
What does the Arnold log say?
Set the verbosity level to debug.
https://arnoldsupport.com/category/logs/
https://linktr.ee/cg_oglu
a.szertaridisz
Thank you for taking the time!
I attached the log file after the render. Can you make something of it?
Alexisz
a.szertaridisz
Hey,@Christoph_Schaedl
Did you manage to take a look at it?
Christoph_Schaedl
I cant see anything special. Maybe @Stephen.Blair can find something?
Stephen.Blair
I don't see 2 hours per frame.
Three frames were rendered: 11 min, 35 min, and 36 min.
It's a 2 core machine?
(starting 4 bucket workers of size 64x64 ...)
// Stephen Blair
// Arnold Renderer Support
a.szertaridisz
That was from another batch. I constantly render sequences and preview single frames and doing so I noticed
that the single frame render is much faster. So my actual question was; shouldn't it take equal amount of time to render images per frame one by one and in sequence?
for example: from the 3 images you see in the log, the 11 min long render would probably be close to
a single frame render time. But why do the 2 others take more than twice as long?
Shouldn't they be about  10 min as well?
I have an nVIDIA quadro 1000m.
Stephen.Blair
It's hard to say because the logs from the interactive session are missing information.
Can you restart Maya before you do another render sequence?
And then, in the Arnold Render Settings, can you go to the Diagnostics tab:
  • Set the Verbosity Level to Info (that's almost always good enough, we rarely need Dedug level logs)
  • Enable File
  • Choose a location and file name for your log files (you can just enter "arnold.log", MtoA will automatically create one log file per frame).
  • Render a few frames.
If you're not using the latest MtoA, I would consider upgrading too.
// Stephen Blair
a.szertaridisz
I ran a short sequence with the settings you requested!
I attached the log files for the 5 frames I made! Can you take a look?
thanks!
a.szertaridisz
Hi, @Stephen.Blair
Have you had a chance to take a look at the files I uploaded?
