Is there a way to turn off cast shadows in toon shader?
nnetzYWHA4
nnetzYWHA4
I am attempting to create an animated scene with stylized lighting where a shadowed motorcyclist in a deserted setting drives towards distant mountains. Every object in the scene has a toon shader applied to it in order to give it a stylized look. The problem I'm running into is that the motorcycle and telephone wires on the sides of the road cast shadows onto the mountains. Silhouette isn't turned on, and additional lights do not get rid of the pitch black shadows. I'm inexperienced with the toon shader and lighting setups in general, so does know have a solution?
Here is a screenshot to show what the scene currently looks like. the mountains are also casting shadows on those further in the background.Screenshot 2024-02-27 170838.png
Stephen.Blair
Turn off Cast Shadows on the geometry?
// Stephen Blair
// Arnold Renderer Support
nnetzYWHA4
Doing that turned off the shadow the front mountain casted on the behind one, but turning off the cast shadows on the other objects didn't seem to do anything.
As another update, I noticed that the closer I get to the mountains, the objects without drop shadow have an outlined silhouette
Left: poles without drop shadow
Right: poles with drop shadow
nnetzYWHA4
nvm, that's from the toon shader's outline
Problem solved!
