Is there a way I can select all the faces which are assigned to a certain material?
Solved by J450NP13. Go to Solution.
this is not an answer to selecting faces, only objects with said materials. If you have an object with multiple materials then this can be a problem.
The problem is only when you want to select the faces of only one of many objects that have this particular shader between many others. If you have one object with multi materials, it select only the faces with your choice on the object.
Use this Python script.
import maya.cmds as mc # select object or face b = mc.ls(sl=1)[0].split("[")[0] # remember a token for comparison below mc.hyperShade(smn=1) # that will select the shader s = mc.ls(sl=1)[0] # remember the selected shader sg = mc.listConnections(s+".oc", s=0, d=1)[0] # figure out the shading group # select the faces of the same object with same shader attached l = [] for o in mc.sets(sg, q=1): if b not in o: continue l.append(o) mc.select(l)
Hi, I really need this script to work, as I have multiple objects which have multiple shaders assigned. However, I'm receiving this error for a given material:
Error: ValueError: file <maya console> line 6: No object matches name: Metal.oc
"Metal" is the shader I'm trying to switch out with a different one on my selected object. Can this be fixed?
My specs:
Maya '20
Win10 64bit
Thanks so much in advance.
Hi Andy,
If you need to select another shader, specify the index (change 0 by another index) :
s = mc.ls(sl=1)[0]
For the ".oc" problem, replace :
sg = mc.listConnections(s, s=0, d=1)[0]
