how to add blur to ai cell noise
wzwow
wzwow
is that possible to do in hypershade editor?
daunish
No, Maya and Arnold currently have no blur function.
The best thing to do would be to make a texture externally and blur it there. You could also bake your texture and then process it in PS.
The closes thing you can do in Maya is run a noise into the cell noise node. The attached image is a super high-frequency noise running into the offset of a cell noise. It could work for what you need, but as you can see, it fails once you get close to the object.
Good luck!
