HOW CAN I LOAD SEQUENCE OF UDIM TEXTURES MAYA 2017
mexxmexx
Message 1 of 8
mexxmexx
I HAVE A SEQUENCE OF UDIM TEXTURES
I LOADED THIS SEQUENCE IN A FILE TEXTURE NODE AND I MADE UV TILING MODE = UDIM MARI AND ACTIVATE USE IMAGE SEQUENCE
WHEN I RENDER IT APPEARS GRAY NO TEXTURES
FRAME 0
UV FRAME 0
FRAME 1
UV FRAME 1
HOW CAN I LOAD THIS UDIM SEQUENCE
Replies (7)
Message 2 of 8
Lindsey_Robbins
So, to confirm: you have an image sequence that has multiple udims, and it's showing up in the viewport, but not in the render, correct?
First test: load the first frame as NOT a sequence, just a single file. Do both spheres render? If not, it's not the sequence that's causing the issue.
If they do show up fine as a UDIM set without being an image sequence, but go back to gray as soon as you load them as a sequence, that might be a bug? I'd have to bounce that up the chain to @sean.heasley .
Message 3 of 8
Lindsey_Robbins
... Wait, what happens if you change your mapping to 0 based, like, zbrush?
Message 4 of 8
sean.heasley
Hi @mexxmexx
If you haven't already I'd recommend following this tutorial.
Message 5 of 8
sean.heasley
Hi @mexxmexx
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 6 of 8
mexxmexx
thank you for your help after many times of trying it works well in maya 2018 via ai image but it didnt work in maya 2017 thank you lindsey
Message 7 of 8
mexxmexx
thank you very much sean this solution is great thanx man
Message 8 of 8
Found this solution but was unhappy with all the texture laying needed just to get UDIM to work.  I found that I can just...
1. add an aiimage
2. check use file sequence
3. edit expression in frame to (aiImage1.frame=frame)
4. change the UDIM in the file name to <udim>
5. change the frame number in the file name to #### (The Maya style <f> doesn't seem to work here)
This seems to work perfectly.  I'm in Maya 2020 and I realize that this is an older post and things may have changed since this thread was started, does it also work in older versions?   I thought I'd add this just in case anyone else is searching for an easier solution.  Seems like the #### frame substitution is undocumented, or at least I couldn't find it.
