Automatic UV- how to match texture file to it?
I have a mesh with a textured uv map but it is extremely complicated and unorganized. I want to use the automatic uv function but then it no longer matches the textured image file. Is there a work around to generate a new, textured uv map to match the automatic mapping?
thanks!
mspeer
Hi!
Try in Render menu:
Lighting/Shading -> Transfer Maps...
