Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Arnold render aborted (Maya 2020, MtoA 4.2.0, Arnold core 6.2.0.0, RTX 3080)
2 REPLIES 2
880 Views, 2 Replies
Arnold was working fine, besides the occasional crash (most likely due to GPU overheating). Because of this, I set the max temperature lower for the 3080. After that (which isn't necessarily related), Arnold aborts the render and tosses this in the output. The same error occurs even if I reset everything. I've reinstalled Maya, Arnold, reset the GPU configurations, etc. My scene is too much for the CPU, so any help would be appreciated.
[gpu] an error happened during rendering. OptiX error is: Unknown error (Details: Function "_rtContextLaunch2D" caught exception: Encountered a CUDA error: cudaDriver().CuEventSynchronize( m_event ) returned (700): Illegal address, file: <internal>, line: 0)
Labels (5)
2 REPLIES 2
Full Log:
00:00:51  4086MB         | [color_manager] using color manager of type "color_manager_syncolor"
00:00:51  4086MB         | [color_manager] rendering color space is "scene-linear Rec 709/sRGB" with declared chromaticities:
00:00:51  4086MB         |                 r(0.6400, 0.3300) g(0.3000, 0.6000) b(0.1500, 0.0600) and w(0.3127, 0.3290)
00:00:51  4086MB         |
00:00:51  4086MB         | rendering image at 1920 x 1920, 3 AA samples
00:00:51  4086MB         |   AA samples max    <disabled>
00:00:51  4086MB         |   AA sample clamp   <disabled>
00:00:51  4086MB         |   diffuse           samples  3 / depth  1
00:00:51  4086MB         |   specular          samples  2 / depth  1
00:00:51  4086MB         |   transmission      samples  2 / depth  5
00:00:51  4086MB         |   volume indirect   samples  2 / depth  5
00:00:51  4086MB         |   total                          depth 10
00:00:51  4086MB         |   bssrdf            samples  2
00:00:51  4086MB         |   transparency      depth 5
00:00:51  4086MB         | initializing 2080 nodes ...
00:00:51  4086MB         |  creating root object list ...
00:00:51  4086MB         | node initialization done in 0:00.00 (multithreaded)
00:00:51  4086MB         | updating 2080 nodes ...
00:00:51  4086MB         |  aiAtmosphereVolume: atmosphere_volume using 45 samples
00:00:51  4086MB         |  scene bounds: (-4.28543758 3.38625717 -3.96354008) -> (4.40497541 15.5414095 4.08605289)
00:00:51  4086MB         | node update done in 0:00.01 (multithreaded)
00:00:51  4086MB         | [gpu] updating 2080 nodes ...
00:00:51  4086MB         | [gpu] GPU update done in 0:00.007
00:00:51  4086MB         | [aov] parsing 2 output statements ...
00:00:51  4086MB         | [aov] registered driver: "arv_display" (driver_arv)
00:00:51  4086MB         | [aov]  * "RGBA" of type RGBA filtered by "defaultArnoldFilter/box_filter" (box_filter)
00:00:51  4086MB         | [aov]  * "object" of type POINTER filtered by "_renderViewDefault/closest_filter" (closest_filter)
00:00:51  4086MB         | [aov]  * "denoise_albedo" of type RGB filtered by "defaultArnoldFilter/box_filter" (box_filter)
00:00:51  4086MB         | [aov]  * "N" of type RGB filtered by "defaultArnoldFilter/box_filter" (box_filter)
00:00:51  4086MB         | [aov]  * "Z" of type FLOAT filtered by "defaultArnoldFilter/box_filter" (box_filter)
00:00:51  4086MB         | [aov]  * "RGBA" of type RGBA filtered by "" (variance_filter)
00:00:51  4086MB         | [aov] done preparing 6 AOVs for 6 outputs to 1 driver (0 deep AOVs)
00:00:51  3916MB         | starting render ...
00:00:51  3917MB         |  [gpu] building scene and compiling shaders ...
00:00:51  3917MB         |  [gpu] building scene and compiling shaders done in 0:00.000
00:00:52  3941MB         |   10% done (0/9 samples per pixel)
00:00:53  4419MB         |   21% done (1/9 samples per pixel)
00:00:54  4453MB         |   32% done (2/9 samples per pixel)
00:00:55  4462MB         |   43% done (3/9 samples per pixel)
00:00:56  4464MB         |   54% done (4/9 samples per pixel)
00:00:57  4466MB         |   65% done (5/9 samples per pixel)
00:00:58  4467MB         |   76% done (6/9 samples per pixel)
00:00:59  4469MB         |   87% done (7/9 samples per pixel)
00:01:00  4470MB         |   98% done (8/9 samples per pixel)
00:01:05  4473MB         |  100% done (9/9 samples per pixel)
00:01:06  4473MB         |  [gpu] final stack size : direct 12336 continuation 7368 memory pool size (used) 4096(1056)
00:01:06  4473MB         | render done in 0:14.768
00:01:30  4562MB         | render done
00:01:30  4563MB         | [color_manager] using color manager of type "color_manager_syncolor"
00:01:30  4563MB         | [color_manager] rendering color space is "scene-linear Rec 709/sRGB" with declared chromaticities:
00:01:30  4563MB         |                 r(0.6400, 0.3300) g(0.3000, 0.6000) b(0.1500, 0.0600) and w(0.3127, 0.3290)
00:01:30  4563MB         |
00:01:30  4563MB         | rendering image at 1920 x 1920, -3 AA samples
00:01:30  4563MB         |   AA samples max    <disabled>
00:01:30  4563MB         |   AA sample clamp   <disabled>
00:01:30  4563MB         |   diffuse           samples  2 / depth  1
00:01:30  4563MB         |   specular          samples  2 / depth  1
00:01:30  4563MB         |   transmission      samples  2 / depth  5
00:01:30  4563MB         |   volume indirect   samples  2 / depth  5
00:01:30  4563MB         |   total                          depth 10
00:01:30  4563MB         |   bssrdf            samples  2
00:01:30  4563MB         |   transparency      depth 5
00:01:30  4563MB         | initializing 2085 nodes ...
00:01:30  4563MB         |  creating root object list ...
00:01:30  4563MB         | node initialization done in 0:00.00 (multithreaded)
00:01:30  4563MB         | updating 2085 nodes ...
00:01:30  4563MB         |  aiAtmosphereVolume: atmosphere_volume using 45 samples
00:01:30  4568MB         |  scene bounds: (-2843.38281 -16.3549309 -3110.82666) -> (2843.38281 106.740494 2575.93896)
00:01:30  4568MB         | node update done in 0:00.04 (multithreaded)
00:01:30  4568MB         | [gpu] updating 2085 nodes ...
00:01:30  4588MB         | [gpu] GPU update done in 0:00.137
00:01:30  4588MB         | [aov] parsing 2 output statements ...
00:01:30  4588MB         | [aov] registered driver: "arv_display" (driver_arv)
00:01:30  4588MB         | [aov]  * "RGBA" of type RGBA filtered by "defaultArnoldFilter/box_filter" (box_filter)
00:01:30  4588MB         | [aov]  * "object" of type POINTER filtered by "_renderViewDefault/closest_filter" (closest_filter)
00:01:30  4588MB         | [aov]  * "denoise_albedo" of type RGB filtered by "defaultArnoldFilter/box_filter" (box_filter)
00:01:30  4588MB         | [aov]  * "N" of type RGB filtered by "defaultArnoldFilter/box_filter" (box_filter)
00:01:30  4588MB         | [aov]  * "Z" of type FLOAT filtered by "defaultArnoldFilter/box_filter" (box_filter)
00:01:30  4588MB         | [aov]  * "RGBA" of type RGBA filtered by "" (variance_filter)
00:01:30  4588MB         | [aov] done preparing 6 AOVs for 6 outputs to 1 driver (0 deep AOVs)
00:01:30  4123MB         | starting render ...
00:01:30  4124MB         |  [gpu] building scene and compiling shaders ...
00:01:31  4240MB         |  [gpu] (1/6) Compiled program closest_hit_sss in 0:00.236
00:01:31  4247MB         |  [gpu] (2/7) Compiled program closest_hit_probe in 0:00.422
00:01:36  4948MB         |  [gpu] (3/8) Compiled program closest_hit in 0:05.100
00:01:40  4932MB         |  [gpu] (4/9) Compiled program standard_surface_Evaluate in 0:08.968
00:01:40  4930MB         |  [gpu] (5/10) Compiled program miss in 0:04.305
00:01:50  5098MB         |  [gpu] (6/11) Compiled program ShaderGlobalsShadeAtmosphere in 0:19.515
00:01:58  4869MB         |  [gpu] (7/12) Compiled program shade_atmosphere in 0:27.007
00:01:58  4903MB         |  [gpu] (8/12) Compiled program any_hit_opaque_shadows in 0:18.063
stanleylam0512
Any update for getting this fixed? Currently having same problems with my 3090
