Arnold batch render stops after 3 frames
le_daiii
le_daiii
Hello.
I have a 250 frame animation to render, and each time I am launching the batch render, arnold works fine for 3 frames, then stops as if it was done, displaying the message :
// Rendering Completed. See mayaRenderLog.txt for information. //
 I can launch a new batch render, and it will render the 3 next frame before, again, stopping as if it was done. Maya does not crash or display any visible error.
The maya Render log display this error :
00:15:55 703MB ERROR | signal caught: error C0000005 -- access violation
// Maya exited with status -1073741819
After browsing different forums, here are the solutions I have tried without success :
- disabling "abort on errror"   (render settings>diagnosis)
- renumbering frames from 1, since my animation is frame 376 to 615 (render settings>common>frame range)
- unchecking "autodetect threads" and setting th threads to 1 (render settings>system)
-check and uncheck "skip existing frames"
-rendering with "render sequence" instead of batch render (maya simply closed after the usual 3 frames rendered)
-resettings maya's prefs
(I turned on auto detect thread since it solved nothing and just made my rendering slower)
I am using Maya 2022.3 on Windows 10. I have a student liscence for both Maya and Arnold. I dont have any watermarks on my images so i dont think it is a liscencing problem.
I also already rendered this scene on the computer at school and it works perfectly, so it is not a scene issue.
I am very unfamiliar with computer hardware but here is the info i have on my computer
Processeur AMD Ryzen 3 1200 Quad-Core Processor 3.10 GHz
RAM installée 16,0 Go
type du système Système d’exploitation 64 bits, processeur x64
GPU AMD Radeon RX 6500 XT (i am rendering on CPU)
I have Maya installed on 2 computers but it is only running on 1. If I dont find any answers soon I will uninstall Maya from both computers and reinstall it on my current one, and upgrade to Maya 2023. But since this will take a while I'm a bit lazy to do it.
Any proposition is welcome at this point.
Replies (7)
Parmenides
Have you tried rendering without 'skip existing frames'? If those frames exist it will stop.  I have had this happen to me but it is usually because I accidentally put 100 in 'by frame'.
le_daiii
I did yes, as seen in the screenshots I included. No results. I'll add it to the list of the things I've tried.
Sorry I misread your comment, you said WITHOUT the skip. Currently trying it, I will update as soon as i get a result.
Parmenides
I did look at the screenshots. It showed that you have selected, not unselected.
le_daiii
It's me again. Just tried to render without "skip existing frames", it still stops... It always stops at exactly 3 frames wich i think is weird... Thanks for the propostition though ! I'll try to reinstall Maya tomorrow. I hope I can get it fixed because my film is due for June... Have a good day
RyanCameron
I'm not 100% sure on this, but fairly certain it won't let you fully batch render using an educational license.
I think Renderman will allow it and not have a watermark?
RB Cameron, AIA, LEED AP, EDAC
Digital Practice Leader
le_daiii
It's my 2nd year of student liscence, last year I had no problem using it, I made a 1000+ frame render without any issue...
No idea what renderman is, I'll check it out! I'm currently reinstalling Maya 2023 to see if updating it will solve the issue.
le_daiii
Reinstalled Maya and it was fixed... I didn't think it would work since I saw other posts stating it was useless. Anyway thanks everyone
