I am new to PySide and am experimenting with it in Autodesk Maya.
I have a text code from Chris Zurbrigg. I am getting a good handle of how to setup a UI, but I am running into one major problem.
How do I retrieve the text from a QLineEdit outside of the class?
Ex:
If the QLineEdit is for a username.
How do I retrieve the username text, in a function, outside of this UI?
Here is the code:----------------------------------------------------------------------------------
import traceback
from PySide import QtCore
from PySide import QtGui
from shiboken import wrapInstance
import maya.cmds as cmds
import maya.OpenMayaUI as omui
def maya_main_window():
Return the Maya main window widget as a Python object
main_window_ptr = omui.MQtUtil.mainWindow()
return wrapInstance(long(main_window_ptr), QtGui.QWidget)
class TestUi(QtGui.QDialog😞
test_signal = QtCore.Signal()
def __init__(self, parent=maya_main_window()):
super(TestUi, self).__init__(parent)
def create(self😞
Create the UI
self.setWindowTitle("TestUi")
self.setWindowFlags(QtCore.Qt.Tool)
self.create_controls()
self.create_layout()
self.create_connections()
def create_controls(self😞
Create the widgets for the dialog
self.push_button = QtGui.QPushButton("QPushButton")
self.check_box_01 = QtGui.QCheckBox("QCheckBox 01")
self.check_box_02 = QtGui.QCheckBox("QCheckBox 02")
txt=[]
self.line_edit = QtGui.QLineEdit()
self.line_edit.setPlaceholderText('Enter Name')
self.line_edit.setToolTip('Enter Your Name in the Text Field.')
self.line_edit.setObjectName('testLineEdit')
self.close_btn = QtGui.QPushButton("Close")
self.close_btn.clicked.connect(self.close)
def create_layout(self😞
Create the layouts and add widgets
check_box_layout = QtGui.QHBoxLayout()
check_box_layout.setContentsMargins(2, 2, 2, 2)
check_box_layout.addWidget(self.check_box_01)
check_box_layout.addWidget(self.check_box_02)
main_layout = QtGui.QVBoxLayout()
main_layout.setContentsMargins(6, 6, 6, 6)
main_layout.addWidget(self.line_edit)
main_layout.addWidget(self.close_btn)
main_layout.addStretch()
self.setLayout(main_layout)
def create_connections(self😞
Create the signal/slot connections
self.line_edit.editingFinished.connect(self.on_text_changed)
# SLOTS
def on_text_changed(self😞
print("Text changed")
print self.line_edit.text()
if __name__ == "__main__":
# Development workaround for PySide winEvent error (Maya 2014)
# Make sure the UI is deleted before recreating
try:
test_ui.deleteLater()
except:
pass
# Create minimal UI object
test_ui = TestUi()
# Delete the UI if errors occur to avoid causing winEvent
# and event errors (in Maya 2014)
try:
test_ui.create()
test_ui.show()
except:
traceback.print_exc()
Ex:
import traceback
def create(self😞
Create the UI
txt=[]
# SLOTS
try:
except:
pass
test_ui = TestUi()
try:
test_ui.create()
test_ui.show()
except:
Solved by cheng_xi_li. Go to Solution.
Hi Nathan,
You can add a method in your TestUi class to expose the string like below:
def getLineText(self): return self.line_edit.text()
If you want to find your window and get its text, you'll need to set an object name for your window. You can add following code in the create function
self.setObjectName('testWindow')
Then, you can use following code to find the window and get the text
mayaMainWindow = maya_main_window() testWindow = mayaMainWindow.findChild(TestUi, "testWindow") print testWindow.getLineText()
Yours,
Li
Hi Nathan,
Yours,
Li
Awesome! Just what I was looking for.
Thank you!
Thank you!
