Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
Random Select Objects in Group by Percentage in Mel?
6 REPLIES 6
victorbennett
3617 Views, 6 Replies
Can someone help me figure out how to write out a way to randomly select objects that are in a group by a percentage in Mel?  I need to embed this into another script I'm making.
Thanks!
Vic
6 REPLIES 6
mcw0
in reply to: victorbennett
string $objects[] = `listRelatives -type "transform" -pa "yourGroup"`;  //  FIRST GET OBJECTS IN GROUP
int $num = size($objects);  //  NUMBER OF OBJECTS
float $percent = 50.0;  //  NOW SET YOUR PERCENTAGE OF OBJECTS TO SELECT
int $numToSelect = ($percent/100.0) * $num;  //  ACTUAL NUMBER OF OBJECTS TO SELECT
//  USE A RANDOM NUMBER FUNCTION TO DETERMINE IF AN OBJECT IS SELECTED OR NOT
float $threshold = $percent/100.0;  //  SINCE THIS EXAMPLE USES 50%, A THRESHOLD OF .5 IS USED
string $list[];  //  RECORD THE OBJECTS TO SELECT
while(size($list) < $numToSelect)  //  KEEP SELECTING UNTIL DESIRED PERCENTAGE IS ACHIEVED
    for($object in $objects)  //  LOOP THROUGH YOUR OBJECTS TO DETERMINE WHICH ARE SELECTED
        if(rand(1) > $threshold)
            $list[size($list)] = $object;
    $objects = stringArrayRemove($list, $objects);  //  REMOVE SELECTED OBJECTS FROM YOUR ORIGINAL LIST
This was typed without trying it in Maya.  But the logic is there.  And I'm pretty sure it will work.  Using a "while" conditional is always hazardous, but in this case, you will eventually hit your percentage so it shouldn't go into an endless loop.  Good luck.
victorbennett
in reply to: mcw0
Thanks!  However, it's not selecting anything and I'm not getting any errors...
Vic
mcw0
I'm so sorry.  I forgot the last line!!!
select -r $list;
victorbennett
in reply to: mcw0
Works great.  Thanks!
shmelov
in reply to: mcw0
This topic made my day. Many thanks to autor, and especialy to mcw0. That script solved a big problem for me!
victorbennett
in reply to: shmelov
So glad it helped!
