Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
Poly modeling cannot be read problem
3 REPLIES 3
bronstetter
7607 Views, 3 Replies
After I downloaded and open up maya, I get a message that says " Warning: the shelf "poly modeling" has items that cannot be read.
Basically, when I select the poly modeling on the toolbar, I don't get any of cube or shapes for me to use. What should I do?
Tags (1)
3 REPLIES 3
mspeer
in reply to: bronstetter
Hi!
Try a reset of your preferences.
Rename the folder prefs in folder 2018 to something like prefs_backup, or to reset everything, the folder 2018 to 2018_backup (or even the maya folder to maya_backup). Maya creates new folders (don't copy preferences from previous Maya versions). Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
bronstetter
in reply to: mspeer
It work, thank you
in reply to: mspeer
It's Awsome ....Working ....
