Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Script Error Origin #MEL
jayantbhatt07
jayantbhatt07
Hi, I'm working on a free Nut_Bolt script but I'm getting an error. Let's say I'm Importing the Bolt_01  it's snapping to the selected face but again when I run this script on a new selected face it's taking back Bolt_01 to the origin. It shouldn't happen like that. For more refer video.
  1. {
  2. // create a window
  3. window -title "jay" -menuBar true -w 220 -h 200 "";
  4. // define the layout of controls added
  5. // to the window.
  6. columnLayout;
  7. // create a collapsible frame layout
  8. frameLayout -collapsable true -label "Nuts";
  9.
  10. // add the other controls
  11. flowLayout -columnSpacing 1 -w 220 -h 30;
  12. symbolButton -image "commandButton.png" -command "sample_Proc";
  13.
  14. setParent ..;
  15.
  16.
  17. // show the window we last created
  18. showWindow;;
  19. }
  20.
  21.
  22.
  23. proc sample_Proc()
  24. {
  25. string $sel_faces[] = `ls -sl `;
  26. file -import "E:/Bolt_01.ma";
  27. select $sel_faces[0] "Bolt_01";
  28. float $rsScale = size($sel_faces);
  29. scale -r $rsScale $rsScale $rsScale "Bolt_01";
  30. string $rspointOnPolyConstraint[] = `pointOnPolyConstraint -offset 0 0 0 -weight 1 `;
  31. delete $rspointOnPolyConstraint;
  32. rename "nut_01" "nutPlaced_01";
  33. makeIdentity -apply true -t 1 -r 1 -s 1 -n 0 -pn 1;
  34. }
haggi
Well, as much as I can see, you always use the very first bolt
And every time a new Bolt is imported it gets a new name. So what happens is: The new Bolt is imported and placed in world center, then the very first "Bolt_01" is snapped to the selected face. I'm not sure, but I think the import command offers a way to get the imported node names which can be used to get the correct name of the imported bolt.
