Hi!
I am trying to build a command in python for Maya following a course on youtube and it's showing this error "# Error: RuntimeError: file line 2: AttributeError: file C:/Users/saeed/OneDrive/Documents/maya/2020/Plugins/vertexParticle.py line 23: 'module' object has no attribute 'MStatus' # "
I checked Maya API documents and we should have "MStatus" class but I have no idea why it's not accepted, I tried to use "MStatusCode" and it's showing same error.
that's my script
from maya import OpenMaya
from maya import OpenMayaMPx
from maya import OpenMayaFX
import sys
commandName = "vertexParticle"
kHelpFlag = "-h"
kHelpLongFlag = "-help"
kSparseFlag = "-s"
kSparseLongFlag = "-sparse"
helpMessage = "This command will attach a particle for each vertex"
class pluginCommand(OpenMayaMPx.MPxCommand):
sparse = None
def __init__(self):
OpenMayaMPx.MPxCommand.__init__(self)
def argumentParser(self, argList):
syntax = self.syntax()
parserArguments = OpenMaya.MArgDatabase(syntax, argList)
if parserArguments.isFlagSet(kSparseFlag):
self.sparse = parserArguments.flagArgumentDouble(kSparseFlag, 0)
return OpenMaya.MStatus.kSuccess
if parserArguments.isFlagSet(kSparseLongFlag):
self.sparse = parserArguments.flagArgumentDouble(kSparseLongFlag, 0)
if parserArguments.isFlagSet(kHelpFlag):
self.setResult(helpMessage)
if parserArguments.isFlagSet(kHelpLongFlag):
def isUndoable(self):
return True
def undoIt(self):
print "undo"
mFnDagNode = OpenMaya.MFnDagNode(self.mObjParticle)
mDagMod = OpenMaya.MDagModifier()
mDagMod.deleteNode(mFnDagNode.parent(0))
mDagMod.doIt()
def redoIt(self):
mSel = OpenMaya.MSelectionList()
mDagPath = OpenMaya.MDagPath()
mFnMesh = OpenMaya.MFnMesh()
OpenMaya.MGlobal.getActiveSelectionList(mSel)
if mSel.length() >= 1:
try:
mSel.getDagPath(0, mDagPath)
mFnMesh.setObject(mDagPath)
except:
print "please select a poly mesh"
return OpenMaya.MStatus.kUnknownParameter
else:
mPointArray = OpenMaya.MPointArray()
mFnMesh.getPoints(mPointArray, OpenMaya.MSpace.kWorld)
mFnParticle = OpenMayaFX.MFnParticleSystem()
self.mObjParticle = mFnParticle.create()
mFnParticle = OpenMayaFX.MFnParticleSystem(self.mObjParticle)
counter == 0
for i in xrange(mPointArray.length()):
if i%self.sparse == 0:
mFnParticle.emit(mPointArray[i])
counter += 1
print "total points :" + str(counter)
mFnParticle.saveInitialState()
def doIt(self, argList):
self.argumentParser(argList)
if self.sparse != None:
self.redoIt()
def cmdCreator():
return OpenMayaMPx.asMPxPtr(pluginCommand())
def syntaxCreator():
syntax = OpenMaya.MSyntax()
syntax.addFlag(kHelpFlag, kHelpLongFlag)
syntax.addFlag(kSparseFlag, kSparseLongFlag, OpenMaya.MSyntax.kDouble)
return syntax
def initializePlugin(mObject):
mPlugin = OpenMayaMPx.MFnPlugin(mObject)
try:
mPlugin.registerCommand(commandName, cmdCreator, syntaxCreator)
except:
sys.stderr.write("Failed to register" + commandName)
def uninitializePlugin(mObject):
mPlugin = OpenMayaMPx.MFnPlugin(pluginCommand())
try:
mPlugin.deregisterCommand(commandName)
except:
sys.stderr.write("Failed to deregister" + commandName)
