‘module’ object has no attribute ‘MStatus' in Maya python Api 2020
saeeddameeres
saeeddameeres
Hi!
I am trying to build a command in python for Maya following a course on youtube and it's showing this error "# Error: RuntimeError: file line 2: AttributeError: file C:/Users/saeed/OneDrive/Documents/maya/2020/Plugins/vertexParticle.py line 23: 'module' object has no attribute 'MStatus' # "
I checked Maya API documents and we should have "MStatus" class but I have no idea why it's not accepted, I tried to use "MStatusCode" and it's showing same error.
that's my script
from maya import OpenMaya
from maya import OpenMayaMPx
from maya import OpenMayaFX
import sys
commandName = "vertexParticle"
kHelpFlag = "-h"
kHelpLongFlag = "-help"
kSparseFlag = "-s"
kSparseLongFlag = "-sparse"
helpMessage = "This command will attach a particle for each vertex"
class pluginCommand(OpenMayaMPx.MPxCommand):
    sparse = None
    def __init__(self):
        OpenMayaMPx.MPxCommand.__init__(self)
    def argumentParser(self, argList):
        syntax = self.syntax()
        parserArguments = OpenMaya.MArgDatabase(syntax, argList)
        if parserArguments.isFlagSet(kSparseFlag):
            self.sparse = parserArguments.flagArgumentDouble(kSparseFlag, 0)
            return OpenMaya.MStatus.kSuccess
        if parserArguments.isFlagSet(kSparseLongFlag):
            self.sparse = parserArguments.flagArgumentDouble(kSparseLongFlag, 0)
        if parserArguments.isFlagSet(kHelpFlag):
            self.setResult(helpMessage)
        if parserArguments.isFlagSet(kHelpLongFlag):
    def isUndoable(self):
        return True
    def undoIt(self):
        print "undo"
        mFnDagNode = OpenMaya.MFnDagNode(self.mObjParticle)
        mDagMod = OpenMaya.MDagModifier()
        mDagMod.deleteNode(mFnDagNode.parent(0))
        mDagMod.doIt()
    def redoIt(self):
        mSel = OpenMaya.MSelectionList()
        mDagPath = OpenMaya.MDagPath()
        mFnMesh = OpenMaya.MFnMesh()
        OpenMaya.MGlobal.getActiveSelectionList(mSel)
        if mSel.length() >= 1:
            try:
                mSel.getDagPath(0, mDagPath)
                mFnMesh.setObject(mDagPath)
            except:
                print "please select a poly mesh"
                return OpenMaya.MStatus.kUnknownParameter
        else:
        mPointArray = OpenMaya.MPointArray()
        mFnMesh.getPoints(mPointArray, OpenMaya.MSpace.kWorld)
        mFnParticle = OpenMayaFX.MFnParticleSystem()
        self.mObjParticle = mFnParticle.create()
        mFnParticle = OpenMayaFX.MFnParticleSystem(self.mObjParticle)
        counter == 0
        for i in xrange(mPointArray.length()):
            if i%self.sparse == 0:
                mFnParticle.emit(mPointArray[i])
                counter += 1
        print "total points :" + str(counter)
        mFnParticle.saveInitialState()
    def doIt(self, argList):
        self.argumentParser(argList)
        if self.sparse != None:
            self.redoIt()
def cmdCreator():
    return OpenMayaMPx.asMPxPtr(pluginCommand())
def syntaxCreator():
    syntax = OpenMaya.MSyntax()
    syntax.addFlag(kHelpFlag, kHelpLongFlag)
    syntax.addFlag(kSparseFlag, kSparseLongFlag, OpenMaya.MSyntax.kDouble)
    return syntax
def initializePlugin(mObject):
    mPlugin = OpenMayaMPx.MFnPlugin(mObject)
    try:
        mPlugin.registerCommand(commandName, cmdCreator, syntaxCreator)
    except:
        sys.stderr.write("Failed to register" + commandName)
def uninitializePlugin(mObject):
    mPlugin = OpenMayaMPx.MFnPlugin(pluginCommand())
    try:
        mPlugin.deregisterCommand(commandName)
    except:
        sys.stderr.write("Failed to deregister" + commandName)
jmreinhart
If you go to this page
https://help.autodesk.com/view/MAYAUL/2022/ENU/?guid=Maya_SDK_Maya_Python_API_Maya_Python_API_1_0_Us...
and go to the section labelled
"Exceptions versus MStatus"
You will find specific info on this issue, but the important bit is:
Users writing plug-ins in Python should raise exceptions rather than return MStatus values, unless they want their compute() method to indicate that it is not going to handle a plug. In this case, it should return maya.OpenMaya.kUnknownParameter.
