Hello there,
I used to customize the old renderView in Maya, with button shortcuts like so:
I am trying to find a way to do the same in the Arnold render view, just to inject a few buttons. Am I right in assuming that the window contents are invisible to Maya as generated in the mtoa plugin ? I can access the window, but nothing within it. Is there any way to access the layouts so I can add some control UI ?
I suppose I could build a small UI and stick it to the window...
//only window or workspaceControl exposure?
window -e - h 450 ArnoldRenderView;
//shows nothing...
workspaceControl -q -uiScript ArnoldRenderView;
Thank you!
