Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
Modification of the Arnold render view.
1 REPLY 1
MrEddie
190 Views, 1 Reply
Hello there,
I used to customize the old renderView in Maya, with button shortcuts like so:
I am trying to find a way to do the same in the Arnold render view, just to inject a few buttons. Am I right in assuming that the window contents are invisible to Maya as generated in the mtoa plugin ?  I can access the window, but nothing within it. Is there any way to access the layouts so I can add some control UI ?
I suppose I could build a small UI and stick it to the window...
//only window or workspaceControl exposure?
window -e - h 450 ArnoldRenderView;
//shows nothing...
workspaceControl  -q -uiScript ArnoldRenderView;
Thank you!
1 REPLY 1
MrEddie
in reply to: MrEddie
I was able to solve it by attaching a UI to the Arnold Renderview. Probably better as no dependancies. Uses an idle event scriptJob but it's light and is more beneficial than worrying about the amount of procedure calls.
So I can make shortcuts to my most used workflows.
