cmds.setAttr(objectName + ".scale", -1, -1, -1)
This results in scale being set to 0.01. How do I set negative scale through script?
If I input -1, into scale channels manually it works, so the object transform itself is not at fault.
Please help, I've been pulling my hair out because this feels so basic but I can't find any solution online.
Solved by brentmc. Go to Solution.
This should work.
Check the attribute editor to make sure there are no min scaling limits set on the transform you are trying to modify.
