Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
Maya Python: How to set negative scale?
2 REPLIES 2
adrianadce
209 Views, 2 Replies
cmds.setAttr(objectName + ".scale", -1, -1, -1)
This results in scale being set to 0.01. How do I set negative scale through script?
If I input -1, into scale channels manually it works, so the object transform itself is not at fault.
Please help, I've been pulling my hair out because this feels so basic but I can't find any solution online.
Tags (2)
Labels (2)
2 REPLIES 2
brentmc
in reply to: adrianadce
This should work.
Check the attribute editor to make sure there are no min scaling limits set on the transform you are trying to modify.
Brent McPherson
Principle Engineer
adrianadce
in reply to: brentmc
You're right.
I've made a mistake while trouble shooting, and didn't notice this. Thank you.
