Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
Is it possible to extrude equally in both directions?
2 REPLIES 2
MayaNZ01
503 Views, 2 Replies
MayaNZ01
Is it possible to extrude equally in both directions? Or is there a script that can already do this? Would be very useful in a lot of scenarios when modeling, and particularly when bringing in garments from MD
Tags (1)
Labels (1)
2 REPLIES 2
Kahylan
in reply to: MayaNZ01
Kahylan
Hi!
I don't think there is a standart tool to do that in Maya.
If this is only about giving clothing from MD some thickness, I wrote a script for that a while back.
But it was only for my own workflow, so it is pretty limited and only works if you select all the faces of the object at the same time.
import maya.cmds as mc
def extrudeFlatObjBothDirections(thick = 0, tz = 0):
    Extrudes selected faces in both directions.
    WARNING: only works properly if all polygons of object are selected
    sl = mc.ls(selection = True) or []
    l = mc.ls(selection = True, fl = True) or []
    ext = mc.polyExtrudeFacet(sl[0], kft = True, thickness = thick, ltz = tz, sma = 30, taper = 1, d = 1, ws = True)
    mc.setAttr('{0}.reverseAllFaces'.format(ext[0]),1)
    ext = mc.polyExtrudeFacet("{0}[{1}:{2}]".format(sl[0].split("[")[0],len(l), 2*len(l)-1), kft = True, thickness = thick, ltz =tz, sma = 30, taper = 1, d = 1, ws = True)
extrudeFlatObjBothDirections(thick = 0, tz = 0.1)
the arg "thick" defines thickness and "tz" defines Translate Z, depending on the mesh one or the other will give you better results.
I hope this helps!
Hi!
I hope this helps!
MayaNZ01
in reply to: Kahylan
MayaNZ01
This works amazing, thank you so much for sharing 🙂
