Hi, I'm just starting to get into building pipeline tools around USD in Maya.
I was looking at the release notes for Maya 2022 and I see quite a number of references to "ufe". However, searching in the documentation or searching via google doesn't find anything that tells me what it is. What is it?
On this page:
There is a reference to UFE 2.0 API documentation but this link is broken and I can find any references to UFE API anywhere else in the documentation or via a google search.
There are several release notes that the python APIs for various functions have changed to take UFE aware paths. What is a UFE aware path?
Chris King
Spire Animation Studios
On this page:
Chris King
Solved by pierre.baillargeon. Go to Solution.
Hi!
ufe is part of the mayaUSD library. As far as I know it helps with importing USD Transforms.
It's kind of hard to explain, especially since I never really worked with it. I only saw presentations about the use of USD in Maya so far.
Like this one for example:
https://www.youtube.com/watch?v=z-w0BktAA-0
Also here is the git repository of ufe, maybe that helps:
https://github.com/Autodesk/maya-usd/tree/dev/lib/mayaUsd/ufe
Like I said, I only have second hand information about USD, but its supposedly a plugin that makes data sharing between programs a lot easier.
I hope this helps and maybe someone can explain it a bit better^^
Hi!
I found a conversation on a discord discussion that said this:
The Maya 2022 Devkit has quite thorough documentation for UFE, hidden in devkitBase/devkit/ufe/sdk-doc.zip https://t.co/TvaFZ4bQDw #maya #techArt #usd #ufe https://t.co/BlmRbO5AES
So I went looking for the dev kit. I got to this page:
https://github.com/sonictk/Maya-devkit
I clicked on the link to download the windows version and got this message:
This app is currently unreachable or unpublished.
Hmm...
Hmm...
Hi Chris,
Here is a link to the UFe 2.0 documentation: https://help.autodesk.com/view/MAYAUL/2022/ENU/?guid=Maya_SDK_ufe_ref_index_html
Sorry for the bad link in the USD page you referred to.
Hi Chris,
