Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
Error: Line 1.1: Syntax error
6 REPLIES 6
bektastunc790
9515 Views, 6 Replies
how can i fix this // Error: Line 1.1: Syntax errorerror.PNG
when i select something in outliner this pop up coming up
Labels (2)
6 REPLIES 6
e_honda
in reply to: bektastunc790
Check this thread. Probably duplicate:
Error: <function selCom at 0x7f29c5c04aa0>;
Hope it helps.
bektastunc790
in reply to: e_honda
i found the solution just delete the "prefs" or rename "prefsold"
A syntax error is one of several types of errors on calculators (most commonly found on scientific calculators and graphing calculators ), representing that the equation that has been input has incorrect syntax of numbers, operations and so on.
Certain syntax errors can be as follows:
missing semicolons
unbalanced parenthesis
missing operators
indentation
error in the structure of the program
Greeting,
Rachel Gomez
tmaoP3JHS
what pre,the name of project file ?
bektastunc790
in reply to: tmaoP3JHS
c/documents/maya/2022/prefs
tmaoP3JHS
cheers mate.
