- Mute
- Permalink
- Report
how can i fix this // Error: Line 1.1: Syntax error
when i select something in outliner this pop up coming up
i found the solution just delete the "prefs" or rename "prefsold"
A syntax error is one of several types of errors on calculators (most commonly found on scientific calculators and graphing calculators ), representing that the equation that has been input has incorrect syntax of numbers, operations and so on.
Certain syntax errors can be as follows:
missing semicolons
unbalanced parenthesis
missing operators
indentation
error in the structure of the program
Greeting,
Rachel Gomez
what pre,the name of project file ?
