What's wrong with this code?
Message 1 of 1
this is my code time does not update....what's wrong in run_time method?
please help....
from PyQt4 import QtGui, QtCore
import maya.OpenMayaUI as mui
import sip
def maya_main_window():
ptr = mui.MQtUtil.mainWindow()
return sip.wrapinstance(long(ptr), QtCore.QObject)
class RenamingDialog(QtGui.QDialog):
def __init__(self, parent= maya_main_window()):
QtGui.QDialog.__init__(self,parent)
self.setWindowTitle("Clock")
self.setFixedSize(250, 200)
self.createLayout()
self.button_update()
self.run_time()
def run_time(self):
self.timer = QtCore.QTimer(self)
self.connect(self.timer, QtCore.SIGNAL("timeout()"), self, QtCore.SLOT("update_time()"))
self.timer.start()
def createLayout(self):
self.button1 = QtGui.QPushButton("Ok")
self.label = QtGui.QLabel("time")
buttonLayout = QtGui.QHBoxLayout()
buttonLayout.addWidget(self.button1)
buttonLayout.addWidget(self.label)
mainLayout = QtGui.QVBoxLayout()
mainLayout.addLayout(buttonLayout)
self.setLayout(mainLayout)
def update_time(self):
self.time = QtCore.QTime.currentTime()
self.updater = QtCore.QString(self.time.toString("hh:mm:ss"))
self.label.setText(self.updater)
def button_update(self):
self.connect(self.button1, QtCore.SIGNAL("clicked()"), self.printer)
def printer(self):
print "hai",
if __name__ == "__main__":
dialog = RenamingDialog()
dialog.show()
thank you.
Replies (0)
