what is my deformer issues?
egoldid1
egoldid1
hi,
this is compute function in my deformer node:
MArrayDataHandle inputDataArray = data.inputArrayValue(input);
inputDataArray.jumpToArrayElement(0);
MDataHandle meshData = inputDataArray.inputValue().child(inputGeom);
//mesh:
MObject inMesh = meshData.asMesh();
MFnMesh inMeshFn;
inMeshFn.setObject(inMesh);
//======== output:outMeshFn, geometry data.
MDataHandle outputData = data.outputValue(plug);
outputData.copy(meshData);
MObject outMesh = outputData.asMesh();
MFnMesh outMeshFn;
outMeshFn.setObject(outMesh);
//============ define neccessary variables:
MFloatPointArray points, newpoints;
MFloatVectorArray inNormals;
inMeshFn.getPoints(points, MSpace::kWorld);
inMeshFn.getNormals(inNormals, MSpace::kWorld);
newpoints = points;
for (int index = 0; index < points.length(); index++)
newpoints[index] = points[index] + 3 * envelope_attr*inNormals[index].normal();
outMeshFn.setPoints(newpoints, MSpace::kWorld);
data.setClean(outputGeom);
why this deformer doesn't quite work??
( i want Move Vertex along point normal direction)
olarn
I think the normals were wrong because that function is returning list of all face-vertex normals data not 1 normal per vertex so calculations would be off. The index in to that array is not vtx id as you expected but the "normal id" for a particular face-vtx.
The normals are the per-polygon per-vertex normals.
http://help.autodesk.com/cloudhelp/2018/ENU/Maya-SDK/cpp_ref/class_m_fn_mesh.html#a638962fd4d516c8b1...
Perhaps consider query per vtx normal using this instead. (or get polygon normal id etc and look it up manually)
http://help.autodesk.com/cloudhelp/2018/ENU/Maya-SDK/cpp_ref/class_m_it_mesh_vertex.html#a160d912ad4...
Christoph_Schaedl
You could also rebuild your deformer in Bifrost to get a better understanding whats goin on.
https://www.youtube.com/watch?v=SPQ5vB4qKQQ
https://linktr.ee/cg_oglu
