Announcements
suffix to an object error?
jayantbhatt07
Message 1 of 12
jayantbhatt07
Why this command is giving me an error
(// Error: Line 2.46: Syntax error)
string $selObjs[] = ls -sl;
for( $obj in $selObjs ) group -name ( $obj + “_Ctrl” ) $obj;
Replies (11)
Message 2 of 12
mspeer
Hi
string $selObjs[] = `ls -sl`;
for( $obj in $selObjs ) group -name ( $obj + "_Ctrl" ) $obj;
Message 3 of 12
g2m.agent
for( $obj in $selObjs ){
1. ls need to be surrounded by special markers. its the button under ESC.
2. _Ctrl must use the quotes of the English keyboard
Message 4 of 12
jayantbhatt07
Hi see the screenshot. I selected multiple objects and what this script does made a separate group for each object. It should make only one group for all the selected objects.
Message 5 of 12
g2m.agent
group -name ( $selObjs[0] + "_Ctrl" ) $selObjs;
Message 6 of 12
jayantbhatt07
Thank you so much for your help.
I have one question I already asked on so many forums but looks like nobody has the answer I hope you have. Why we cant use the repeat command (#G ) with the same value which we used in the previous extrude ( Or action) I know we can copy and paste attributes but tha is pain in the head. Do you know any command for that?
@g2m.agent  @mspeer
Message 7 of 12
mspeer
Hi!
Maya does this by default.
However if however you change values AFTER using the command, this will not be included for repeat.
Message 8 of 12
jayantbhatt07
Hi in my 1st extrude the value was 0.848 and after that when I hit G command all values are by default set to zero. Which is I dont want.
Message 9 of 12
mspeer
Hi!
This In-View Editor affects the values of the node in the history AFTER the command was already executed and the node created, it's a different interface than Attribute Editor, but comparable.
You can't reuse node edits for repeat.
Message 10 of 12
jayantbhatt07
Ok thank you so much for the info. 🙂
Message 11 of 12
g2m.agent
It needs to be improved indeed, based on my experience with Maya, I think this process could take 5 years.
Message 12 of 12
jayantbhatt07
haha man then I need to post it on maya idea forum LOL
