Announcements
Melscript to select "all keyable" in channels line of Set Key options
Hi, I'm looking for a Melscript to select "all keyable" in channels line of Set Key options, to avoid open this window all the time I open Maya, if you find a way it would be very useful, thank you
mspeer
Hi!
This setting should be saved with preferences.
Just set the correct value, apply the effect or use Edit -> Save Settings,
then save preferences.
This should make this the default for every Maya start.
Thanks for this answer but when I save preferences and reopen a scene it return to default so it doesn't work for me with this solution
mspeer
Hi!
Please try a reset of your preferences.
Rename the folder prefs in folder 2018 to something like prefs_backup, or to reset everything, the folder 2018 to 2018_backup (or even the maya folder to maya_backup). Maya creates new folders (don't copy preferences from previous Maya versions). Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
What Maya version are you using?
OS?
Any 3rd party plug-ins?
It's unlikely a scene changes the behavior of this tool (if not intended by any scrips included in the scene)
If a scene resets this, please upload the scene.
Thank you, I tried this solution and it works, it was a preferences problem, I'm on linux debian and maya 2019, thanks for have resolved this
