Unrecognized file type
Hello everyone
so i have a very serious problem i hope you can help me
I am in a Maya scene 2009 64bit record in .mb and this secene is saving under lock usb when I change pc I install this 2009 in 32 bit I work on it and I have to save my scene and here is the problem
my scene is .mb became 0ko and when I open it the message says "Unrecognized File"
I hope this problem can be solved because it is a big scene voila
mspeer
Hi!
If the file size is 0KB, then the file is corrupted and all data is lost. If you don't have a backup file you have to start again with a new scene.
I am very disappointed for this reason
I think it exits a solution after video https://www.youtube.com/watch?v=k6o--vj5aEA
and this tutorial of this forum if it is the case
and technology advances if someone has a solution
haggi_master
The video talks about recovering a damaged file with the help of incemental saves and a file diff tool. If you do not have any incremental saves and your file has 0kb, it is damaged and everything is lost. But it would not help anyway because 0kb means there is no information about it and additionally, your format is binaray what would not work anyway.
