Undo and redo heeelllp ;(
Message 1 of 9
i have some api code that creates a curve:
import maya.OpenMaya as om
positions=[(1,2,3),(0,2,3),(2,3,4),(5,2,4)]
curveFn = om.MFnNurbsCurve()
arr = om.MPointArray()
for pos in positions:
    arr.append(*pos)
obj = curveFn.createWithEditPoints(
                                  arr,
                                  3,
                                  om.MFnNurbsCurve.kOpen,
                                  False,
                                  False,
                                  True
but i want to implement undo functionality. I have an example piece of template code that is setup for undo/redo but i just dont know how and where to add my curve creation code to this to make it undoable.
here is the template code for undo/redo:
# sampleUndoableCommand.py
import sys
import maya.OpenMayaMPx as OpenMayaMPx
kPluginCmdName = 'myUndoableCommandName'
class MyUndoableCommand( OpenMayaMPx.MPxCommand ):
    def __init__(self):
        OpenMayaMPx.MPxCommand.__init__(self)
    def doIt(self, args):
        self.redoIt()
    def redoIt(self):
        pass
    def undoIt(self):
        pass
    def isUndoable(self):
        return True
if anyone could help me out id really appreciate it thanks!!,
Sam
Replies (8)
Message 2 of 9
cheng_xi_li
Autodesk Support
Autodesk Support
Hi roger21,
There is a C++ sample called helixTool may help you.
Since it is C++, I'll explain it shortly here.
In the helixTool sample,  redoIt() creates a curve and store the path by calling curveFn::getPath in the end.
For undoIt(), it uses the path it stores earlier to remove the transform node it created.
Yours,
Li
Message 3 of 9
cool Li, many thanks
Message 4 of 9
ok, maybe no one will see this, but have written a small plugin that creates a curve in maya. and i am trying to implement the undo to delete the curve transform, but im a bit stuck. So far here is my code:
import sys, math
kPluginCmdName="createCurve"
class curveTest(OpenMayaMPx.MPxCommand):
	def __init__(self):
		self.redoIt()
	def redoIt(self):
		#create the curve
			arr.append(*pos)
		try:
			if True:
				curveTransform = curveFn.createWithEditPoints(
												  arr,
												  3,
												  False,
												  False,
												  True
			else:
				print "no"
		except:
			sys.stderr.write( "Error creating curve.\n" )
			raise
	def undoIt(self):
		pass
		#delete curve here
		return True
def cmdCreator():
	return OpenMayaMPx.asMPxPtr( curveTest() )
def initializePlugin(mobject):
	mplugin = OpenMayaMPx.MFnPlugin(mobject)
	try:
			mplugin.registerCommand( kPluginCmdName, cmdCreator)
	except:
			sys.stderr.write( "Failed to register command: %s\n" % kPluginCmdName )
			raise
def uninitializePlugin(mobject):
	try:
			mplugin.deregisterCommand( kPluginCmdName )
	except:
			sys.stderr.write( "Failed to unregister command: %s\n" % kPluginCmdName )
			raise
i saw an example of how to do this elswhere but it doesnt work in my script. I guess because its not written in python syntax?
MFnDagNode dagFn(curveTransform)
MObject child;
child = dagFn.child(0);
MGlobal::deleteNode(child);
MGlobal::deleteNode(curveTransform);
could anyone give me some pointers here?.
also, if a curve creation functon is called many times throughout a script, would there just be a way to delete all the API created curves in one go? or do they need to be deleted in a particular way?
thanks alot,
Sam
Message 5 of 9
cheng_xi_li
Autodesk Support
Autodesk Support
Like the C++ sample, you can use curveFn.getPath to store the path and try to delete it with MGlobal.deleteNode later.
Or you can store the transform like this
self.curveTransform = curveFn.createWithEditPoints(
And delete it later
def undoIt(self):
om.MGlobal().deleteNode(self.curveTransform) ....
For more details about python and c++ APIs, here is the link to the reference for Python API 1.0 and link to Python API 2.0
Yours,
Li
Message 6 of 9
thanks Li, your a genius!
Sam
Message 7 of 9
just out of interest,
if there have been multiple curves generated throughout my script would i need to somehow record all the transform nodes of all the api generated curves and delete in a list. or i could delete all in one go?
thanks
Sam
Message 8 of 9
cheng_xi_li
Autodesk Support
Autodesk Support
Hi roger21,
I think you can try this method in this document which uses MDagModifier.
Yours,
Li
Message 9 of 9
nice one Li, these docs are much friendlier than the ones i had been using
thanks,
Sam
