Select every other edge?
Message 1 of 33
Hello, guys.
Can anybody remind me the script in MEL how to select every other edge?
Thanks in advance.
Replies (32)
Message 2 of 33
Simply call:
InvertSelection;
Message 3 of 33
Thanks, but it not what I want.
"Invert selection" - just inverting the selection.
But i want to select one face (or edge) - then one skip - again select - again skip...etc..
Message 4 of 33
mspeer
Hi!
There is nothing like "select every nth component" in Maya.
Message 5 of 33
there was a script for Maya 2015 or 2016 i don`t remember
Message 6 of 33
This script should do it, maybe there are better ways, not sure.
// Get node of selected edge
string $nodeName = "pSphereShape1";
// First/Starting edge index
int $edgeStart = 0;
// Get the number of edges from the node int $edgeCount[] = `polyEvaluate -edge $nodeName`; if (size($edgeCount) > 0) {
// Clear the selection select -clear; int $e;
// Loop through all edges and add every second edge to the selection for ($e = $edgeStart; $e < $edgeCount[0]; $e += 2) { select -add ($nodeName + ".e[" + $e + "]"); } }
Message 7 of 33
thank you, i`ll try it.
Message 8 of 33
Hey,
You can use these depending on what you need to select. Select an edge and execute.
polySelectEdgesEveryN "edgeRing" 2;
polySelectEdgesEveryN "edgeLoop" 2;
Cheers,
Fearwar
Message 9 of 33
mspeer
Hi!
In Maya 2018 for command polySelect there is a new option -everyN.
Message 10 of 33
PixelDeluxe
Cheers for that, it worked perfectly!
Message 11 of 33
where it is? i can`t find
Message 12 of 33
Roland.Reyer
In the Bonus Tools for Maya 2018 you find it under "Modelling->Select every Nth Edge in a Loop/Ring"
The Bonus Tools can be found here: https://area.autodesk.com/bonustools/
Message 13 of 33
thanks a lot
Message 14 of 33
nandooo_
You are a genius!
Is that possible to make this script work also for selecting every other face and vertex?
Message 15 of 33
This guy...Heart
Do you have a solution for faces as well perhaps?
Message 16 of 33
with latest Bonus tool its very simple to select every n- edge, it have this tool
Message 17 of 33
JHShark
Observer
Observer
Found this blog:
http://mayazest.blogspot.se/2017/07/select-every-other-edge-loop.html
Worked in Maya 2018.
Test selecting an edge and using this:
Message 18 of 33
Nice solution, looks like mine 🙂
Message 19 of 33
JHShark
Observer
Observer
Ah true, missed it 😛
Message 20 of 33
I have 2018 and 2019 LT. I ran the MSI and was informed that install was successful but it does not show up in 2019 and I have no way of really knowing if it worked for 2018 as I already have bonus tools installed for 2018 and am not familiar enough with it to know if any changes were made.
