Announcements
Playblast and VP2 floating point render target issue
szabolcs.horvatth
szabolcs.horvatth
I'd like to do a playblast using the floating point precision enabled in the VP2 settings, but it seams that the playblast command does not respect this setting at all. Is there a way to specify the floating point render target for the playblast command or using a global setting somewhere?
Cheers,
Szabolcs
カワダチアキ
Autodesk Support
Autodesk Support
After Maya 2016 Extention2, this issue was fixed.
If you encounter this issue with Maya2017, please let me know your Playblast option.
